Use this procedure to graphically view IPsec statistics and counter values for each IPsec-enabled interface.
If you select an interface on the Stats tab, you can select Graph to graph particular statistics for that interface.
 - Select IPSec.
 - Select the Interface Stats tab.
 - Select a row, and Select Graph.
 - Select one of the parameters, and Select the appropriate icon in the upper-left corner of the menu bar to draw a line chart, area chart, bar chart, or a pie chart.
 - To clear existing counters, and fix a reference point in time to restart the counters, Select Clear Contents.
 - To export the statistical data to a file, select Export.
 - To configure a poll interval, select an appropriate value from the Poll Interval drop-down list.
