Use the following procedure to configure the maximum number of sessions on the switch. The max-sessions value configures the number of times a particular role-based user can log in to the switch through the SSH session at the same time. The default max-sessions value is 3.
The max-sessions value applies only for SSH sessions, and only with enhanced secure mode enabled.
You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
Configure the reuse rule to 5:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password max-sessions 5 user-name jsmith Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password max-sessions command.
Variable |
Value |
<1–8> |
Specifies the maximum number of sessions. The default is 3. |
user-name WORD<1–255> |
Specifies the user-name. |
