Use the following procedure to enable or disable SPBM at the global level. SPBM uses the Intermediate-System-to-Intermediate-System (IS-IS) link state routing protocol to provide a loop free Ethernet topology that creates a shortest path topology from every node to every other node in the network based on node MAC addresses.
 - Select SPBM.
 - Select the Globals tab.
 - To enable or disable SPBM, select enable or disable in GlobalEnable.
 - To configure the global ethertype value, select the desired option in GlobalEtherType.
 - Select Apply.
Use the data in the following table to use the Globals tab.
                                 Name  |
                                 Description  |
                                 GlobalEnable  |
                                 Enables or disables SPBM globally. The default is disabled. To ensure proper cleanup of MAC tables after you disable SPBM, save the configuration, and then reboot the switch.  |
                                 GlobalEtherType  |
                                 Specifies the global ethertype value as 0x8100 or 0x88a8. The default value is 0x8100.  |
                                 NicknameServerEnable  |
                                 Enables or disables the nickname server. The default is disabled.  |
                                 NicknameDynamicAllocationStatus  |
                                 Displays the Dynamic Nickname Allocation service operational status.  |
                                 NicknameServerPrefix  |
                                 Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default is A.00.00.  |
