Create the Forwarding Profile
A forwarding profile is a collection of port and destination pairs. When you configure UDP forwarding list entries, be sure to first configure the UDP forwarding list. Then, configure your UDP forwarding list entries and assign them to a UDP forwarding list. If you do not assign a UDP forwarding list entry to at least one UDP forwarding list, the UDP forwarding list is lost after a restart.
Forwarding Lists Field Descriptions
Use the data in the following table to use the Forwarding Lists tab and Insert Forwarding Lists dialog box.
 Name  |
 Description  |
 Id  |
 Specifies a value that uniquely identifies this list of entries (1 to 1000).  |
 Name  |
 Specifies an administratively assigned name for this list (0 to 15 characters).  |
 FwdIdList  |
 Specifies the zero or more port forwarding entries associated with this list. Each list identifier is stored as 2 bytes in this array, starting from 0 bytes (size=64). Select the ellipsis (...) to display the ID list.  |
