Unable to Log On by any Means
If you cannot log on by any means, perform the following steps.
Check if you enabled both TACACS+ and RADIUS on the switch:
Switch:1>enable
Switch:1(config)#show tacacs
Global Status:
   global enable : false
   authentication enabled for : cli
   accounting enabled for : none
   authorization : disabled
   User privilege levels set for command authorization : None
Server:
                      create :
Prio   Status  Key     Port  IP address  Timeout Single Source SourceEnabled
Primary NotConn ******   3    192.0.2.254      30   true 5.5.5.5  true
Backup  NotConn ******  47    198.51.100.1      10  false 0.0.0.0 false
Switch:1>show radius
             acct-attribute-value : 193
                      acct-enable : false
        acct-include-cli-commands : false
        access-priority-attribute : 192
             auth-info-attr-value : 91
         command-access-attribute : 194
           cli-commands-attribute : 195
                    cli-cmd-count : 40
               cli-profile-enable : false
                           enable : false
                 igap-passwd-attr : standard
           igap-timeout-log-fsize : 512
                        maxserver : 10
            mcast-addr-attr-value : 90
             supported-vendor-ids : 1584, 562, 1916
                      secure-flag : false
Check if the administrative and operation status of the port is up:
Switch:1#show interface gigabitethernet 1/2
                                 Port Interface
PORT                       LINK  PORT           PHYSICAL          STATUS
NUM   INDEX DESCRIPTION    TRAP  LOCK     MTU   ADDRESS           ADMIN  OPERATE
1/2   257   1000BaseTX     true  false    1950  00:24:7f:a1:70:61 up     up
                                   Port Name
PORT                                               OPERATE  OPERATE  OPERATE
NUM   NAME                           DESCRIPTION   STATUS   DUPLEX    SPEED    VL
AN
1/2                                  1000BaseTX    up       full     1000     Ta
gged
                                  Port Config
PORT                DIFF-SERV   QOS   MLT   VENDOR
--More-- (q = quit)
Check if the switch has a route configured to the server network:
Switch:1(config)#show ip route
                                     IP Route - GlobalRouter
                                                     NH                  INTER
DST             MASK            NEXT                 VRF/ISID       COST FACE  PROT AGE TYPE PRF
198.51.100.1        255.255.255.255 192.0.2.65       GlobalRouter     1   100   OSPF 0   IB   125
198.51.100.5         255.255.255.255 192.0.2.5        -               1   0     LOC  0   DB   0
198.51.100.13        255.255.255.255 			          GlobalRouter     10  1000  ISIS 0   IBS  7
198.51.100.200       255.255.255.255 			          GlobalRouter     10  1000  ISIS 0   IBS  7
4 out of 4 Total Num of Route Entries, 4 Total Num of Dest Networks displayed.
TYPE Legend:
I=Indirect Route, D=Direct Route, A=Alternative Route, B=Best Route, E=Ecmp Rout
e,
U=Unresolved Route, N=Not in HW, F=Replaced by FTN, V=IPVPN Route, S=SPBM Route
PROTOCOL Legend:
v=Inter-VRF route redistributed
      Check if the Segmented Management
                                Instance has a route configured to the server
        network:
Switch:1(config)#show mgmt ip route
                         Mgmt IPv4 Route Information - Table main
DEST/MASK            NEXTHOP              METRIC     INTERFACE       TYPE
198.51.100.0/16      198.51.100.1         300        Mgmt-oob1       STATIC
198.51.100.0/23      0.0.0.0              1          Mgmt-oob1       LOCAL
192.0.2.0/8          192.0.2.1            300        Mgmt-oob1       STATIC
3 out of 3 Total Num of mgmt ip route displayed
