Use the following procedure to view the IKE version 2 security association.
 - Select IKE.
 - Select the V2 SA tab.
V2 SA Field Descriptions
Use the data in the following table to use the V2 SA tab.
 Name  |
 Description  |
 Id  |
 Specifies the profile ID.  |
 LocalIfIndex  |
 Specifies the Interface Index of the local address. Only port and vlan interfaces are supported.  |
 LocalAddrType  |
 Specifies whether the local address is an IPv4 or IPv6 address.  |
 LocalAddr  |
 Specifies the address of the local peer.  |
 RemoteAddrType  |
 Specifies whether the remote address is an IPv4 or IPv6 address.  |
 RemoteAddr  |
 Specifies the address of the remote peer.  |
 Name  |
 Specifies the name given to the SA.  |
 AuthenticationMethod  |
 Specifies the proposed authentication method for theVersion 2 security association. The default authentication method is pre-shared key.  |
 DPDTimeout  |
 Specifies the Dead Peer Detection timeout in seconds.  |
 HashAlgorithm  |
 Specifies the hash algorithm negotiated for this IKE Version 2 SA.  |
 EncryptionAlgorithm  |
 Specifies the encryption algorithm negotiated for this IKE Version 2 SA.  |
 EncryptKeyLen  |
 Specifies the encryption key length negotiated for this IKE Version 2 SA.  |
 DHGroup  |
 Specifies the Diffie-Hellman group negotiated for this IKE Version 2 SA.  |
 ExchangeMode  |
 Specifies the IKE Version 2 SA mode.  |
 LifetimeSeconds  |
 Specifies the amount of time for which an IKE Version 2 SA can remain valid during IKE Version 2 negotiation. A value of 0 means no the SA always remains valid.  |
 Status  |
 Specifies whether the SA is active or inactive.  |
 Initiator  |
 Specifies whether specifies the whether the SA is created by an initiator or a responder.  |
 IntegrityAlgorithm  |
 Specifies the type of integrity algorithm.  |
