Edit system identification information, configuration file information, and perform system actions.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the System tab.
  4. Enter or edit the information as required.
  5. Select Apply.
System Field Descriptions
Use the data in the following table to use the System tab.
Name
Description
sysDescr
Shows the system assigned name and the software version.
sysUpTime
Shows the elapsed time since the system last started.
sysContact
Configures the contact information.
sysName
Configures the name of this device.
sysLocation
Configures the physical location of this device.
VirtualIpAddr
Configures the virtual IP address that the CPU advertises and stores in the switch configuration file.
VirtualNetMask
Configures the net mask of the virtual management IP address.
VirtualIpv6Addr
Specifies the virtual IPv6 address.
VirtualIpv6PrefixLength
Specifies the length of the virtual IPv6 address prefix (in bits).
DnsDomainName
Configures the default domain for querying the DNS server.
LastChange
Displays the time since the last configuration change.
LastVlanChange
Displays the time since the last VLAN change.
LastStatisticsReset
Displays the time since the statistics counters were last reset.
LastRunTimeConfigSave
Displays the last run-time configuration saved.
DefaultRuntimeConfigFileName
Displays the default Run-time configuration file directory name.
ConfigFileName
Specifies the name of a new configuration file.
ActionGroup1
Performs one of the following actions:
  • resetCounters— Resets all statistic counters.
  • saveRuntimeConfig— Saves the current run-time configuration.
  • loadLicense— Loads a software license file to enable features.
LicenseFileName
Specifies the name of the license file in the /intflash directory.
ActionGroup2
Specifies the following action:
resetlstStatCounters—Resets the IST statistic counters
ActionGroup3
Can be the following action:
  • flushIpRouteTbl—flushes IP routes from the routing table
ActionGroup4
  • softReset—resets the device without running power-on tests
  • resetConsole—resets the switch console
  • softResetCoreDump—reset with coredump
Result
Displays a message after you select Apply.
LocatorLED
Note:
Exception: only supported on VSP 4900 Series.
Configures the system Locator LED on or off. The default is off.
