Use the following procedure to display C-VLAN I-SID information.
Switch:1>show vlan i-sid
Vlan I-SID
VLAN_ID I-SID I-SID NAME
1
10 100 Hospital-Server-10
90 1000 ISID-1000
3 out of 3 Total Num of Vlans displayed
Switch# show isis spbm i-sid all
SPBM ISID INFO
ISID SOURCE NAME VLAN SYSID TYPE HOST_NAME ISID NAME AREA AREA NAME
101001 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101001 HOME area-0.00.20
101003 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101003 HOME area-0.00.20
101005 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101005 HOME area-0.00.20
101007 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101007 HOME area-0.00.20
101009 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101009 HOME area-0.00.20
101011 1.11.16 4051 0200.10ff.fff0 discover area-0.00.10 ISID-101011 HOME area-0.00.20
Total number of SPBM ISID entries configed: 0
Total number of SPBM ISID entries discovered: 6
Total number of SPBM ISID entries: 6
Switch:# show vlan mac-address-entry
Vlan Fdb
VLAN MAC SMLT
ID STATUS ADDRESS INTERFACE REMOTE TUNNEL
1 learned 00:1d:42:6b:10:03 Port-1/9 false SwitchB
1 learned 00:80:2d:22:ac:46 Port-1/15 false SwitchB
2 self a4:25:1b:51:48:84 103.103.103.103 false -
2 self 02:01:03:ff:ff:ff Tunnel_to_HQ false -
5 learned 00:00:00:00:00:1a access false SwitchB
10 self 00:00:00:00:49:50 Port-1/9 false -
10 self 00:00:00:50:00:50 Port-1/9 false -
Switch# show vlan remote-mac-table 100
Vlan Remote Mac Table
VLAN STATUS MAC-ADDRESS DEST-MAC BVLAN DEST-SYSNAME PORTS SMLTREMOTE
100 learned 00:15:40:af:d2:00 00:74:00:00:00:00 20 Switch-6005 MLT-2 false
100 learned b4:a9:5a:04:c8:83 b4:a9:5a:04:c8:65 3 Switch-174 103.103.103.103 true
100 learned b4:a9:5a:04:c8:84 b4:a9:5a:04:c8:66 3 Switch-175 Tunnel_to_HQ true
3 of 3 matching entries out of total of 3 Remote Mac entries in all fdb(s) displayed.
Variable definitions
The following table defines parameters for the show vlan commands.
Variable |
Value |
i-sid <1-4059> |
Displays I-SID information for the specified C-VLAN. |
mac-address-entry [spbm-tunnel-as-mac] |
Displays the bridging forwarding database. Use the optional parameter, spbm-tunnel-as-mac to display the BMAC in the TUNNEL column. If you do not use this optional parameter, the TUNNEL column displays the host name. If an entry is not learned in the SPBM network, the TUNNEL column will be empty (–). |
remote-mac-table <1-4059> |
Displays C-VLAN remote-mac-table information. |
The following table defines parameters for the show isis commands.
Variable |
Value |
spbm i-sid {all|config|discover} |
vlan <1-4059> |
Displays I-SID information for the specified SPBM VLAN. |
id <1–16777215> |
Displays I-SID information for the specified I-SID. |
nick-name <x.xx.xx> |
Displays I-SID information for the specified nickname. |
