Perform this procedure to filter for specific VLAN tag priorities.
The ACL exists.
The ACE exists.
 - Select Advanced Filters (ACE/ACLs).
 - Select the ACL tab.
 - Select the appropriate ACL.
 - Select ACE.
 - Select the appropriate ACE.
 - Select Eth.
 - Select the Vlan Tag Priority tab.
 - Select Insert.
 - Specify the operation type.
 - In the VlanTagPrio box, select the priority bits.
 - Select Insert.
VLAN Tag Priority Field Descriptions
Use the data in the following table to use the Vlan Tag Priority tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 VlanTagPrio  |
 Specifies the priority bits (3-bit field) from the 802.1Q/p tag:
 OperMask  |
 Specifies the mask value in hexadecimal format if the Oper value is mask.  |
