You must enable EAPOL globally and at the port level.
Configure a client to enable processing of dynamic session changes.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#radius dynamic-server client 192.0.2.15 port 1025 secret 123 enable
The following table defines parameters for the radius dynamic-server command.
Variable |
Value |
client WORD<0-255> |
Specifies the client address or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS. |
enable |
Enable processing of dynamic session changes. |
port <1024-65535> |
Specifies the port value. |
secret WORD<0-32> |
Specifies a value for secret key. |
