Perform the following procedure to display the MSTP, CIST port, and MSTI port information maintained by every port of the common spanning tree.
show spanning-tree mstp port role [slot/port[/sub-port][-slot/port[/sub-port]][,...]]
If your platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
Display the MSTP port information:
CIST Port Roles and States
Port-Index Port-Role Port-State PortSTPStatus PortOperStatus
1/3 Disabled Discarding Enabled Disabled
