Perform this procedure to view information about the operating status of the power supplies.
 - Select Power Supply.
 - Select the Detail tab.
Detail Field Descriptions
Use the data in the following table to use the Detail tab.
                                 Name  |
                                 Description  |
                                 Type  |
                                 Describes the type of power used. Note: To know what
                                    power types the switch supports, see the hardware installation
                                    documentation.
                                 Description  |
                                 Provides a description of the power supply.  |
                                 SerialNumber  |
                                 Specifies the power supply serial number.  |
                                 HardwareRevision  |
                                 Specifies the hardware revision number.  |
                                 PartNumber  |
                                 Specifies the power supply part number.  |
                                 PowerSupplyOperStatus  |
                                 Specifies the status of the power supply as one of the following:
                                 InputLineVoltage  |
                                 Displays the input line voltage:
                                 OutputWatts  |
                                 Displays the output power of this power supply.  |
                                 VoltageIn  |
                                 Specifies the input voltage value in millivolts (mV) for the power supply unit.  |
                                 Specifies the output voltage value in millivolts (mV) for the power supply unit.  |
                                 CurrentIn  |
                                 Specifies the input current value in milliamps (mA) for the power supply unit.  |
                                 CurrentOut  |
                                 Specifies the output current value in milliamps (mA) for the power supply unit.  |
                                 PowerIn  |
                                 Specifies the input power value in milliwatts (mW) for the power supply unit.  |
                                 PowerOut  |
                                 Specifies the output power value in milliwatts (mW) for the power supply unit.  |
