Enable the Controller
Enable the Controller globally.
 - Select SPBM.
 - In the row for the SPBM, double-click McastSpbPimGwControllerEnable, and then select true.
 - Select Apply.
SPBM Field Descriptions
Use the data in the following table to use the SPBM tab.
 Name  |
 Description  |
 McastSpbPimGwControllerEnable  |
 Enables or disables the ISIS multicast SPM-PIM Gateway Controller node.  |
 McastSpbPimGWGatewayEnable  |
 Enables or disables the ISIS multicast SPM-PIM Gateway node.  |
