Use the following procedure to view IPv6 Mroute information for an interface.
 - Select IPv6 Mroute.
 - Select the Interfaces tab.
Interfaces Field Descriptions
Use the data in the following table to use the Interfaces tab.
 Name  |
 Description  |
 IfIndex  |
                                 Displays the slot and port number or VLAN ID for this entry.  |
 Ttl  |
                                 Displays the datagram time-to-live (TTL) threshold for the interface. IPv6 multicast datagrams with a TTL less than this threshold are not forwarded out of the interface. The default value of 0 means that all multicast packets are forwarded out of the interface.  |
 Protocol  |
                                 Displays the protocol as one of the following:
