Enable an IP routing protocol on VLAN Layer 3 interfaces.
Ensure VLANs with Layer 3 interfaces participate in Split MultiLink Trunking (SMLT).
Configure RSMLT on a VLAN to exchange Layer 3 information between peer nodes in a switch cluster. This configuration applies to both IPv4 and IPv6.
The VLAN can be either IPv4 or IPv6, or both. RSMLT configuration on a VLAN simultaneously affects both IPv4 and IPv6.
 - Select VLANs.
 - Select the Basic tab.
 - Select a VLAN.
 - Select IP.
 - Select the RSMLT tab.
 - Select Enable.
 - In HoldDownTimer, type a hold-down timer value.
 - In HoldUpTimer, type a holdup timer value.
 - Select Apply.
RSMLT Field Descriptions
Use the data in the following table to use the RSMLT tab.
 Name  |
 Description  |
 Enable  |
 Enables RSMLT. The default is disabled.  |
 HoldDownTimer  |
 Defines how long the recovering or restarting system remains in a non-Layer 3 forwarding mode for the peer router MAC address. The range of this value is from 0 to 3600 seconds. The default is 60. If you disable RSMLT on a VLAN, non default values for this field do not save across restarts.  |
 HoldUpTimer  |
 Defines how long the RSMLT system maintains forwarding for its peer. The value is a range from 0 to 3600 seconds or 9999. 9999 means infinity. The default is 1800. If you disable RSMLT on a VLAN, non default values for this field do not save across restarts.  |
