Configure MSDP Mesh Groups
Configure mesh groups to reduce SA flooding. A mesh group does not forward SA messages to other
            group members. The originator, which is also a mesh group member, forwards SA messages
            to all group members. Create MSDP mesh groups from a group of meshed MSDP speakers from
            a domain.
The MSDP router does not belong to any mesh group by default.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp mesh-group helloworld 21.0.0.2
Variable definitions
The following table defines parameters for the ip msdp mesh-group command.
 Variable  |
 Value  |
 WORD<1-64>  |
 Specifies the mesh group name.  |
 {A.B.C.D}  |
 Specifies the MSDP peer IP address.  |
