This tab is not available for hardware platforms with only fixed configuration; it is available for platforms where you can install modules in slots, for example, a Versatile Interface Module (VIM).
- In the Device Physical View tab, select the module slot.
 - Select Card.
 - Select the Card tab.
Card Field Descriptions
Use the data in the following table to use the Card tab.
                                                   Name  |
                                                   Description  |
                                                   CardType  |
                                                   Displays the model number of the module.  |
                                                   SerialNum  |
                                                   Shows the serial number for the installed module.  |
                                                   PartNumber  |
                                                   Shows the part number.  |
                                                   CardAssemblyDate  |
                                                   Shows the date the module was assembled.  |
                                                   CardHWConfig  |
                                                   Shows the hardware revision.  |
