Create a new group membership to logically group users who require the same level of access.
There are several default groups (public and private) created that you can use. To see the list of default groups and their associated security names (secnames), enter show snmp-server group. If you use one of these groups, there is no need to create a new group.
 - Select VACM Table.
 - Select the Group Membership tab.
 - Select Insert.
 - From the SecurityModel options, select a security model.
 - In SecurityName, type a security name.
 - In GroupName, type a group name.
 - Select Insert.
Group Membership Field Descriptions
Use the data in the following table to use the Group Membership tab.
 Name  |
 Description  |
 SecurityModel  |
 Specifies the security model to use with this group membership.  |
 SecurityName  |
 Specifies the security name assigned to this entry in the View-based Access Control Model (VACM) table. The range is 1–32 characters.  |
 GroupName  |
 Specifies the name assigned to this group in the VACM table. The range is 1–32 characters.  |
