Display key health information about the type of packets and protocols received on a port. This command helps debug high CPU utilization issues.
You can use the packets-per-second information in the output to identify where the bulk of packets destined for the CPU enter the switch.
Switch:1>show khi cpp port-statistics
         KHI CPP Details - Port Statistics
Port      Packet Type                           Rx Packets   Rx Diff    Rx Pps   Tx Packets   Tx Diff    Tx Pps
347 seconds since issuing the last KHI command.
1/2       Ether2_LLDP(3)                                 0         0         0          522        12         0
1/2       Ether2_ARP_Request(10)                        18         0         0         3706        48         0
1/2       Ether2_ARP_Other(11)                         104         0         0           18         0         0
1/2       Ether2_Ipv4_Other(19)                         20         0         0            0         0         0
1/2       LLC_BPDU(93)                                   0         0         0         7811       174         0
1/2       LLC_TDP(94)                                    0         0         0         2594        58         0
1/12      Ether2_LLDP(3)                               521        12         0          521        12         0
1/12      LLC_TDP(94)                                 2598        58         0         2594        58         0
1/12      LLC_ISIS(95)                                3105        69         0         3151        69         0
1/13      Ether2_LLDP(3)                               521        12         0          521        12         0
1/13      Ether2_ARP_Request(10)                      3121        69         0         3126        70         0
1/13      Ether2_ARP_Other(11)                        3123        70         0         3121        69         0
1/13      Ether2_IPv4_UDP_Other(16)                   3236        69         0            0         0         0
1/13      LLC_TDP(94)                                 2592        58         0         2594        58         0
1/13      LLC_ISIS(95)                                   0         0         0         3176        68         0
1/14      Ether2_LLDP(3)                               521        12         0          521        12         0
1/14      Ether2_ARP_Request(10)                        42         1         0           26         0         0
1/14      Ether2_ARP_Other(11)                          24         0         0            0         0         0
1/14      LLC_TDP(94)                                 2594        60         0         2596        58         0
1/23      Ether2_LLDP(3)                               520        12         0          521        12         0
1/23      LLC_TDP(94)                                    0         0         0         2596        58         0
1/24      Ether2_LLDP(3)                                 0         0         0          521        12         0
1/24      LLC_TDP(94)                                    0         0         0         2596        58         0
1/s1      Ether2_ARP_Request(10)                       853        20         0         3140        72         0
1/s1      Ether2_ARP_Other(11)                        3114        72         0          853        20         0
1/s1      Ether2_IPv4_UDP_Other(16)                   3781        92         0            0         0         0
1/s1      LLC_BPDU(93)                                   0         0         0         7816       179         0
1/s1      LLC_ISIS(95)                                   0         0         0         3784        93         0
