Use this procedure to view or configure FA I-SID-to-VLAN assignment information.
 - Select Fabric Attach.
 - Select the Assignment tab.
 - If you make configuration changes, select Apply to save changes.
Assignments Field Descriptions
Use the data in the following table to use the Assignments tab.
 Name  |
 Description  |
 IfIndex  |
 Specifies the interface identifier of the I-SID-to-VLAN assignment.  |
 Isid  |
 Specifies the I-SID value of the I-SID-to-VLAN assignment.  |
 Vlan  |
 Specifies the VLAN ID component of the I-SID-to-VLAN assignment.  |
 State  |
 Specifies the current state of the I-SID-to-VLAN assignment. It can be one of the following values:
 Origin  |
 Specifies the origin information of the I-SID-to-VLAN assignment.  |
                             Isid name  |
                             Specifies the I-SID name.  |
