Enable VRRP Global Variables
Enable VRRP global variables to enable the VRRP function.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
 - Select VRRP.
 - Select the Globals tab.
 - Configure the required features.
 - Select Apply.
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 NotificationCntl  |
 Indicates whether the VRRP-enabled router generates SNMP traps
for events.
 The default is enabled.  |
 PingVirtualAddrEnable  |
 Configures whether this device responds to pings directed to a virtual router IP address. The default is enabled.  |
