Use this procedure to view the Neighbor Discovery inspection statistics on a port or set of ports.
The following table defines parameters for the show ipv6 fhs statistics nd-inspection command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
