Use the following procedure to display information about the configuration of RADIUS dynamic session changes.
Switch:1#show radius dynamic-server
RADIUS Dynamic Authorization General Info
CLIENT UDP CLIENT SECRET
ADDRESS PORT ENABLED KEY
192.0.2.15 1026 Disabled ****************
192.0.2.16 1027 Disabled ****************
host.example.com 3799 Enabled ****************
All 2 out of 2 Total Num of RADIUS Dynamic Authorization clients displayed
Display dynamic server statistics:
Switch:1#show radius dynamic-server statistics
RADIUS Dynamic Authorization Global Statistics
Disconnects From Invalid Client Addresses: 0
CoAs From Invalid Client Addresses: 0
The following table defines parameters for the show radius dynamic-server command.
Variable |
Value |
client |
Display RADIUS Dynamic Authorization configuration values for the specified client. |
statistics |
Display statistics for RADIUS Dynamic Authorization clients. |
