            Configure a port as trusted or untrusted to determine the Layer 3 QoS actions the
                switch performs. A trusted port honors incoming DSCP markings. An untrusted port
                overrides DSCP markings. The default is trusted.
                In the navigation pane, expand
                Select Port QoS
                    Config.
                In the row for the port,
                    double-click the cell in the Layer3Trust
                    column.
                Select core (trusted) or
                        access
                    (untrusted) as the port setting.
                Select Apply.
