Perform the following procedure to display the PoE power measurement. You can view the voltage, amperage, and wattage for every PoE port. PoE ports without a powered device (PD) in use are measured as zeros.
For information about which ports support PoE, see the hardware documentation.
- In the Device Physical View, select one or more ports that support PoE.
 - Select General.
 - Select PoE Power Measurement.
PoE Power Measurement Field Descriptions
Use the data in the following table to use the PoE Power Measurement tab.
                                 Name  |
                                 Description  |
                                 Voltage(volts)  |
                                 Displays the power measured in volts.  |
                                 Current(amps)  |
                                 Displays the power measured in amps.  |
                                 Power(watts)  |
                                 Displays the power measured in watts.  |
