View power information to see the amount of power available and used by the chassis and all components.
- On the Device Physical View, select the Device.
- Select Chassis.
- Select the Power Info tab.
Power Info Field Descriptions
Use the data in the following table to use the Power Info tab.
Name |
Description |
TotalPower |
Shows the total power for the chassis. |
RedundantPower |
Shows the redundant power for the chassis. |
