Configure the notify table to select management targets to receive notifications, as well as the type of notification to send to each management target.
For more information about the notify filter table, see RFC3413.
Switch:1(config)#snmp-server notify-filter profile3 99.3.6.1.6.3.1.1.4.1
Switch:1(config)#show snmp-server notify-filter
                          Notify Filter Configuration
Profile Name                     Subtree                           Mask
profile1                         +99.3.6.1.6.3.1.1.4.1             0x7f
profile2                         +99.3.6.1.6.3.1.1.4.1             0x7f
profile3                         +99.3.6.1.6.3.1.1.4.1             0x7f
The following table defines parameters for the snmp-server notify-filter command.
 Variable  |
 Value  |
 WORD<1-32> WORD<1-32>  |
 Creates a notify filter table. The first instance of WORD<1-32> specifies the name of the filter profile with a string length of 1–32. The second instance of WORD<1-32> identifies the filter subtree OID with a string length of 1–32. If the subtree OID parameter uses a plus sign (+) prefix (or no prefix), this indicates include. If the subtree OID uses the minus sign ( – ) prefix, it indicates exclude. You do not calculate the mask because it is automatically calculated. You can use the wildcard character, the asterisk (*), to specify the mask within the OID. You do not need to specify the OID in the dotted decimal format; you can alternatively specify that the MIB parameter names and the OIDs are automatically calculated.  |
