View OSPF statistics to analyze trends. You can also graph statistics for all OSPF packets transmitted by the switch.
 - Select OSPFv3.
 - Select Stats.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 TxPackets  |
 Shows the count of sent packets.  |
 RxPackets  |
 Shows the count of received packets.  |
 TxDropPackets  |
 Shows the count of sent, dropped packets.  |
 RxDropPackets  |
 Shows the count of received, dropped packets.  |
 RxBadPackets  |
 Shows the count of received, bad packets.  |
 SpfRuns  |
 Shows the count of intra-area route table updates with calculations using this area link-state database.  |
 LastSpfRun  |
 Shows the count of the most recent SPF run.  |
 LsdbTblSize  |
 Shows the size of the link state database table.  |
 BadLsReqs  |
 Shows the count of bad link requests.  |
 SeqMismatches  |
 Shows the count of sequence mismatched packets.  |
 Routes  |
 Shows the number of OSPF routes added to the routing table.  |
 Adjacencies  |
 Shows the number of existing adjacencies.  |
 Areas  |
 Shows the number of configured areas.  |
 Nbrs  |
 Shows the number of OSPF neighbors.  |
