Use this procedure to enable IP Multicast over Fabric Connect globally on the Backbone Edge Bridges (BEBs) that directly or indirectly (using Layer 2 switches) connect to IP multicast senders or receivers. By default, IP Multicast over Fabric Connect is disabled. There is no need to enable IP Multicast over Fabric Connect on the Backbone Core Bridges (BCBs).
IP Multicast over Fabric Connect uses I-SIDs starting at 16,000,000 and above. If Layer 2 or Layer 3 I-SIDs are in this range, the system displays an error message and the switch does not enable IP Multicast over Fabric Connect.
You must enable IP multicast over Fabric Connect globally on all DvR enabled nodes (Controllers and Leaf nodes) in a DvR domain.
You must configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
You must create the customer VLANs (C-VLANs) and add slots/ports.
You must add IST slot/ports to the C-VLAN for an SMLT topology.
Enable IP Multicast over Fabric Connect globally:
Switch:1>show vlan i-sid
Vlan I-SID
VLAN_ID I-SID I-SID NAME
1
10 100 Hospital-Server-10
90 1000 ISID-1000
3 out of 3 Total Num of Vlans displayed
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#spbm 1 multicast enable
Variable definitions
The following table defines parameters for the spbm command.
Variable |
Value |
<1–100> |
Enables IP Multicast over Fabric Connect globally. The default is disabled. Specifies the SPBM instance. The switch only supports one instance. |
