The following section provides procedures to configure the DHCP binding table using EDM.
Use the following procedure to add entries for devices with static IP addresses to the DHCP binding table.
- Select DHCP Snooping.
- Select the DHCP Bindings tab.
- Select Insert.
- In VlanId, type the VLAN ID.
- In MacAddress, type the MAC address of the DHCP client.
- In AddressType, select a value.
- In Address, type the IP address of the DHCP client.
- In Interface, select a port.
- In LeaseTime(sec), type the time in seconds.
- Select Insert.
- Select Apply.
DHCP Bindings Field Descriptions
Use data in the following table to use the DHCP Bindings tab.
Name |
Description |
VlanId |
Specifies the VLAN to which the DHCP client belongs. |
MacAddress |
Specifies the MAC address of the DHCP client. |
AddressType |
Specifies the type of address. The default address type is IPv4. |
Address |
Specifies the IP address assigned to the DHCP client. |
Interface |
Specifies the interface to which the DHCP client connects. |
LeaseTime(sec) |
Specifies the lease time (in seconds) of the particular DHCP binding entry. The time range is 0 to 2147483646 seconds. |
TimeToExpiry(sec) |
Species the time of expiry (in seconds) of the DHCP binding entry. |
EntryType |
Specifies the type of the DHCP binding entry.
View DHCP Binding Information
Use the following procedure to view all entries in the DHCP binding table.
Name |
Description |
VlanId |
MacAddress |
AddressType |
Address |
Interface |
LeaseTime(sec) |
TimeToExpiry(sec) |
EntryType |
