Use a protocol-based VLAN so that the VLAN only carries certain traffic types.
                In the navigation pane, expand
                Select VLANs.
                In the Basic tab, select
                        Insert.
                In the Id box, type the
                    unique VLAN ID or use the ID provided.
                In the Name box, type
                    the VLAN name or use the name provided.
                In the Color Identifier
                    box, select the color or use the color provided.
                    This color is used to visually distinguish the VLANs in a network.
                In the MstpInstance box,
                    select the down arrow and choose an MSTI instance from the list.
                In the Type box, select
                        byProtocolId.
                    This activates additional fields needed to configure protocol-based
                        VLANs.
                To specify the VLAN port
                    membership, select the ellipsis (...) for one of
                    the following fields:
                        Port
                            Members
                    OR
                        StaticMembers
                    OR
                        NotAllowToJoin
                Select each port button to
                    choose the desired membership color.
                    Yellow: Potential members—dynamic (potential members are treated as always
                        members)
                    OR
                    Green: Always members—static
                    OR
                    Red: Never members—not allowed to join
Important
                        In a protocol-based VLAN, a potential member becomes an active member of
                            the VLAN after a frame of the specified protocol is received.
                Select Insert.
