View the RMON Log
View the trap log to see which activity occurred.
 - Select Alarms.
 - Select the Log tab.
Log Field Descriptions
Use the data in the following table to use the Log tab.
 Name  |
 Description  |
 EventIndex  |
 Specifies an index that uniquely identifies an entry in the event table. Each entry defines one event that is generated under appropriate conditions.  |
 Index  |
 Specifies an index that uniquely identifies an entry in the log table generated by the same event entries.  |
 Time  |
 Specifies the creation time for this log entry.  |
 Description  |
 Specifies an implementation dependent description of the event that activated this log entry.  |
