Use this procedure to view the LLDP local port information.
 - Select LLDP.
 - Select the Local Port tab.
Local port Field Descriptions
Use the data in the following table to use the Local Port tab.
 Name  |
 Description  |
 PortNum  |
 Specifies the port number.  |
 PortIdSubType  |
 Specifies the type of port identifier.
 PortId  |
 Specifies the identifier associated with the port, on the local system.  |
 PortDesc  |
 Specifies the description of the port, on the local system.  |
