            Change an existing configuration using a table-based tab. You cannot edit grey-shaded
                fields in the table. The following procedure is an illustration on how to use a
                table-based tab.
                You can expand the appropriate folders for any feature you configure and select a
                    table-based tab.
- In the Device Physical
View, select multiple ports.
                In the navigation pane, expand
                Select the VLAN tab.
                    The system displays a table-based tab with the VLAN information.
             - Select a table-based
tab.
 - Double-click a white-shaded
field to edit the value.
                Select the arrow in the list
                    field to view the options, and then choose the appropriate value.
                Double-click a text-entry field
                    and edit the value.
                Select Apply to save the
                    configuration changes.
