Perform the steps in this task to:
Create static routes for data traffic in either the GRT or a specific VRF context for any platform.
Create static routes for a VRF associated with a Segmented Management Instance CLIP interface. Specify the name of the VRF context in Step 1.
Static routes for the management OOB and management VLAN must use the Segmented Management Instance. For more information, see VOSS User Guide. The management CLIP can use the Segmented Management Instance or routes in the associated VRF routing table manager (RTM).
Ensure no black hole static route exists. If a black hole route is enabled, you must first delete or disable it before you can add a regular static route to that destination.
Only black hole routes that belong to the static type protocol are supported. An inter-VRF black hole route is not installed in the routing table of the destination VRF on the same switch.
When you configure a static route with a next-hop-vrf context, you can specify a next-hop IP address that is a locally owned VRRP IP address of the system itself. However, this is not a supported configuration. The best practice is to implement an alternative method of inter-vrf route sharing, such as route redistribution or ISIS accept polices.
For route scaling information and for information on the maximum number of static routes supported on your hardware platform, see VOSS Release Notes.
As a best practice, do not configure static routes on a DvR Leaf node unless the configuration is for reachability to a management network using a Brouter port.
You cannot configure the preference of static routes on a Leaf node.
Create an IP static route, enable a static route, and view the existing IP static routes for the device, or for a specific network or subnet.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip route 192.0.2.2 255.255.0.0 198.51.100.24 weight 20 name ExtSer 10 preference 1
Switch:1(config)#ip route 192.0.2.2 255.255.0.0 198.51.100.24 enable
Switch:1(config)#show ip route static
                          IP Static Route - GlobalRouter
DEST       MASK          NEXT           NH-VRF      COST PREF LCLNHOP STATUS ENABLE NAME      ORIGIN
192.0.2.2  255.255.255.0 198.51.100.24  GlobalRouter 20   1   TRUE    ACTIVE TRUE   ExtSer 10  config
The following table defines parameters for the ip route command.
                                 Variable  |
                                 Value  |
                                 <A.B.C.D A.B.C.D | A.B.C.D/X> <A.B.C.D> <A.B.C.D> <A.B.C.D> <A.B.C.D>  |
                                 Specifies the IP address and mask for the route destination in one of the following formats:
 The third <A.B.C.D> specifies the IP address of the next-hop router (the next router at which packets must arrive on this route). When you create a black hole static route, configure this parameter to 255.255.255.255 as the IP address of the router through which the specified route is accessible.  |
                                 disable  |
                                 Disables a route to the router or VRF.  |
                                 enable  |
                                 Adds a static route to the router or VRF.  |
                                 local-next-hop enable  |
                                 Enables the local next hop for this static route.  |
                                 next-hop-vrf <WORD 1-16>  |
                                 Specifies the next-hop VRF instance by name. After you configure the next-hop-vrf parameter, the static route is created in the local VRF, and the next-hop route is resolved in the next-hop VRF instance (next-hop-vrf).  |
                                 weight <1-65535>  |
                                 Specifies the static route cost. Note:
                                Do not configure a static interface subnet route with a weight of 1.  |
                                 name <1-64>  |
                                 Specifies the name of the static route. You can name the route before or after it is created. Only 32 characters display. The tilde (~) symbol indicates that the name is truncated.  |
                                 preference <1-255>  |
                                 Specifies the route preference.  |
The following table defines parameters for the show ip route static command.
                                 Variable  |
                                 Value  |
                                 <A.B.C.D>  |
                                 Specifies the route by IP address.  |
                                 -s { <A.B.C.D> <A.B.C.D> | default}  |
                                 Specifies the route by IP address and subnet mask.  |
                                 vrf WORD<1-16>  |
                                 Specifies a VRF by name.  |
                                 vrfids WORD<0-512>  |
                                 Specifies a range of VRF IDs.  |
                                 name <1-64>  |
