Delete a dynamically learned route from the routing table if you do not want the switch to use the route. Exercise caution when you delete entries from the routing table.
Delete a dynamically learned route:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#no ip route 192.0.2.32 255.255.255.0 198.51.100.31 dynamic
Use the data in the following table to use the show ip route commands.
                                 Variable  |
                                 Value  |
                                 <A.B.C.D>  |
                                 Specifies the IP address of the route to the network.  |
                                 alternative  |
                                 Displays the alternative routes.  |
                                 count-summary  |
                                 Displays a summary of the number of routes learned from each routing protocol for each VRF.  |
                                 preference  |
                                 Displays the route preference.  |
                                 -s <A.B.C.D/X>  |
                                 Indicates the IP address and subnet mask for which to display routes.  |
                                 -s default  |
                                 Indicates the default subnet.  |
                                 static  |
                                 Displays the static route information.  |
                                 vrf WORD<1-16>  |
                                 Displays the route for a particular VRF.  |
                                 vrfids WORD<0-512>  |
                                 Displays the route for a particular VRF number.  |
                                 spbm-nh-as-mac  |
                                 Displays the spbm route next hop as mac.  |
Use the data in the following table to use the no ip route command.
                                 Variable  |
                                 Value  |
                                 <A.B.C.D A.B.C.D | A.B.C.D/X><A.B.C.D>  |
                                 Specifies the IP address, the subnet mask, and the next-hop IP address, respectively. Specify the IP address and mask for the route destination in one of the following formats:
                                 dynamic  |
                                 Specifies that a dynamic route is to be deleted.  |
                                 enable  |
                                 Disables the route.  |
                                 local-next-hop enable  |
                                 Disables the local-next-hop option.  |
                                 preference  |
                                 Deletes the value of the route preference.  |
                                 next-hop-vrf WORD<1-16>  |
                                 Specifies the name of the next-hop VRF router.  |
