Change the state (active or passive) of PIM on a VLAN interface.
- Before you change
the state of PIM on a VLAN interface, you must first disable PIM to
prevent instability in the PIM operations, especially when neighbors
exist or when the interface receives streams.
                In the navigation pane, expand
                Select VLANs.
                Select the Basic tab.
- Select the VLAN ID
that you want to configure with PIM.
                Select IP.
                Select the PIM tab.
- Clear the Enable check
box.
                Select Apply.
- Select active or passive.
- Reenable PIM on the
VLAN interface.
                Select Apply.
