Use this procedure to generate a certificate signing request (CSR) and store it into a file. This CSR is required to obtain the offline subject certificate.
The following table defines parameters for the certificate generate csr command.
                                 Variable  |
                                 Value  |
                                 <subject-label>  |
                                 Specifies the subject identity.  |
The following table defines parameters for the certificate send-csr-to command.
                                 Variable  |
                                 Value  |
                                 <A.B.C.D>  |
                                 Specifies the IP address for the certificate authority.  |
                                 <remote-path>  |
                                 Specifies the file path on the certificate authority.  |
                                 <subject-label>  |
                                 <user>  |
                                 Specifies the username for the certificate authority.  |
