Configure the Reuse Rule
Use the following procedure to configure the password reuse rule. The default password reuse rule is 3.
You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
Configure the reuse rule to 30:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password password-history 30 Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password password-history command.
 Variable  |
 Value  |
 <3–32>  |
 Configures the minimum number of previous passwords to remember. The default is 3.  |
