Use the following procedure to enable Remote Monitoring (RMON) on an interface.
  • Enable RMON globally.
    enable
    configure terminal
  2. Enable RMON on a particular VLAN:
    vlan rmon <1-4059>
  3. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  4. Enable RMON on a particular port:
    rmon
Enable RMON on VLAN 2:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#vlan rmon 2
Enable RMON on port 1/8:
Switch:1>enable
Switch:1(config)#interface gigabitethernet 1/8
Switch:1(config-if)#rmon
Use the data in this table to use the vlan rmon command.
Variable
Value
<1-4059>
Specifies the VLAN ID on which to configure RMON.
