View Chassis TCP Statistics
View TCP statistics to monitor network performance.
 - Select Chassis.
 - Select the TCP tab.
TCP Field Descriptions
The following table describes parameters on the TCP tab.
 Name  |
 Description  |
 ActiveOpens  |
 The number of times TCP connections made a direct transition to the SYN-SENT state from the CLOSED state.  |
 PassiveOpens  |
 The number of times TCP connections made a direct transition to the SYN-RCVD state from the LISTEN state.  |
 AttemptFails  |
 The number of times TCP connections made a direct transition to the CLOSED state from either the SYN-SENT state or the SYN-RCVD state, plus the number of times TCP connections made a direct transition to the LISTEN state from the SYN-RCVD state.  |
 EstabResets  |
 The number of times TCP connections made a direct transition to the CLOSED state from either the ESTABLISHED state or the CLOSE-WAIT state.  |
 CurrEstab  |
 The number of TCP connections for which the current state is either ESTABLISHED or CLOSE-WAIT.  |
 InSegs  |
 The number of segments received, including those received in error. This count includes segments received on currently established connections.  |
 OutSegs  |
 The number of segments sent, including those on current connections, but excluding those containing only retransmitted octets.  |
 RetransSegs  |
 The number of segments retransmitted that is, the number of TCP segments transmitted containing one or more previously transmitted octets.  |
 InErrs  |
 The number of segments received in error (for example, bad TCP checksums).  |
 OutRsts  |
 The number of TCP segments sent containing the RST flag.  |
 HCInSegs  |
 The number of segments received, including those received in error. This count includes segments received on currently established connections. This object is the 64-bit equivalent of InSegs.  |
 HCOutSegs  |
 The number of segments sent, including those on current connections, but excluding those containing only retransmitted octets. This object is the 64-bit equivalent of OutSegs.  |
