Ensure that the nodes are configured as DvR Leaf nodes, before you configure vIST.
When you configure vIST on a DvR Leaf node pair, the switch generates an I-SID from the configured cluster ID. This I-SID is unique across the SPB network as long as the cluster ID is unique across the SPB network, for the vIST pair. You can configure only one instance of vIST on the Leaf node pair.
To configure vIST, both nodes must be Leaf nodes. You cannot configure vIST, for example, on a Controller-Leaf node pair.
Also both the nodes must belong to the same DvR domain. vIST configuration over Leaf nodes in different domains is not supported.
Configure vIST on DvR Leaf nodes, with IP addresses 51.51.51.1 and 51.51.51.2 respectively:
Switch2:1>enable Switch2:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch2:1(config)#dvr leaf virtual-ist 51.51.51.1 peer-ip 51.51.51.2 cluster-id 255
Switch2:1#show dvr
                          DVR Summary Info
Domain ID                      : 5
Domain ISID                    : 16678219
Role                           : Leaf
My SYS ID                      : 00:bb:00:00:71:23
Operational State              : Up
GW MAC                         : 00:00:5e:00:01:25
Inband Mgmt Clip IP            :
Virtual Ist local address      : 51.51.51.1
Virtual Ist local subnet mask  : 255.255.255.0
Virtual Ist peer address       : 51.51.51.2
Virtual Ist cluster-id         : 255
Virtual Ist ISID               : 16677226
Variable definitions
Use the data in the following table to use the dvr leaf virtual-ist command.
| Variable | Value |
| {<A.B.C.D/X|<A.B.C.D> <A.B.C.D>} | Specifies the local IP (IPv4) address and subnet mask of the node. |
| {<A.B.C.D>} | Specifies the IP address (IPv4) of the vIST peer. |
| <1–1000> | Specifies the cluster ID of vIST. It is set to 0 if vIST is not configured. |
