Configure RADIUS authentication and RADIUS accounting attributes to determine the size of the packets received.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#radius command-access-attribute 192 Switch:1(config)#radius accounting attribute-value 192
The following table defines parameters for the radius command.
                                 Variable  |
                                 Value  |
                                 access-priority-attribute <192-240>  |
                                 Specifies the value of the access priority attribute. The default is 192.  |
                                 accounting {attribute-value <192-240>|enable|include-cli-commands}  |
                                 Configures the accounting attribute value, enable accounting, or configure if accounting includes CLI commands. The default is false.  |
                                 auth-info-attr-value <0-255>  |
                                 Specifies the value of the authentication information attribute.The default is 91.  |
                                 clear-stat  |
                                 Clears RADIUS statistics.  |
                                 cli-cmd-count <1–40>  |
                                 Specifies how many CLI commands before the system sends a RADIUS accounting interim request. The default value is 40.  |
                                 cli-commands-attribute <192-240>  |
                                 Specifies the value of CLI commands attribute. The default is 195.  |
                                 cli-profile  |
                                 Enable RADIUS CLI profiling. CLI profiling grants or denies access to users being authenticated by way of the RADIUS server. You can add a set of CLI commands to the configuration on the RADIUS server, and you can specify the command-access more for these commands. The default is false.  |
                                 command-access-attribute <192-240>  |
                                 Specifies the value of the command access attribute. The default is 194.  |
                                 enable  |
                                 Enable RADIUS authentication globally on the switch.  |
                                 maxserver <1-10>  |
                                 Specific to RADIUS authentication, configures the maximum number of servers allowed for the device. The default is 10.  |
                                 mcast-addr-attr-value <0-255>  |
                                 Specifies the value of the multicast address attribute. The default is 90.  |
                                 secure-flag  |
                                 Specifies whether RADIUS Security (RADSec) is globally enabled. The default is disabled.  |
                                 secure-profile  |
                                 Specifies the RADSec profile name.  |
                                 server host WORD<0–255> key WORD<0–32> [used-by {cli|snmp|web} [acct-enable] [acct-port <1–65536> ] [enable] [port <1–65536> ] [priority <1–10> ] [retry <0–6>secure-enablesecure-log-level {critical | debug | error | info | warning}secure-mode{dtls | tls}secure-profileWORD<1-16> ] [timeout <1–60> ]  |
