DvR backbone members are either DvR Controllers or non-DvR BEBs that receive redistributed host routes from all other DvR Controllers in the SPB network.
Ensure that you enable DvR globally on the node.
 - Select DVR.
 - Select the Backbone Members tab.
 - Optional: To filter the rows based on specific criteria, select Filter.
Backbone Members Field Descriptions
Use the data in the following table to use the Backbone Members tab.
 Name  |
 Description  |
 MacAddress  |
 Specifies the system ID or the nodal MAC address of this DvR backbone member.  |
 SysName  |
 Specifies the system name of this DvR backbone member.  |
 NickName  |
 Specifies the nickname of this DvR backbone member.  |
 Role  |
 Specifies the role of this DvR backbone member. It is either a DvR Controller or a non-DvR BEB.  |
 DomainId  |
 Specifies the domain ID of the DvR domain that this backbone member belongs to. The domain ID is 0 for a non-DvR BEB.  |
