Use the following procedure to display the status of the EAP-based security.
Switch:>enable
Switch:1#config terminal
Switch:1(config)#interface gigabitEthernet 1/2
Switch:1(config-if)#show eapol port 1/2
                         Eapol Configuration
PORT  STATUS  OPER  DYN   Flex-UNI  MAX  QUIET  NON-EAP  LLDP-AUTH  MAX  MAX  MAX   ADMIN    OPER     TRAFFIC         ORIGIN
NUM           MODE  MHSA  ENABLE    REQ  INTVL  ENABLE   ENABLE     MAC  EAP  NEAP  TRAFFIC  TRAFFIC  CONTROL
        CONTROL  CONTROL  ORIGIN
1/2   Auth    MHMV  false true      2    60     false    false      2    2    2     in-out   in-out   CONFIG          CONFIG
                 Eapol Configuration
PORT  REAUTH  REAUTH      REAUTH  REAUTH      GST   GST       FAIL  FAIL      COA     ORIGIN
NUM   ENABLE  ORIGIN      PERIOD  PERIOD      VLAN  I-SID     VLAN  I-SID     ENABLE
                                  ORIGIN
1/2   false   CONFIG      3600    CONFIG      N/A   N/A       N/A   N/A       false   CONFIG
Switch:>enable
Switch:1(config)#show eapol sessions eap verbose
                                   Eap Oper Status Verbose
PORT    MAC               PAE           VLAN  PRI  Flex-UNI I-SID VLAN:I-SID ACL ACEs DYN    RADIUS DYNAMIC
NUM                      STATUS          ID         Enable  SOURCE                    MHSA   SETTINGS
1/13  00:00:11:11:16:02  authenticated    111  1    false  n/a                               DHCPSNOOP, DAI
1/13  00:00:11:11:16:03  authenticated    111  1    false  n/a                               DHCPSNOOP
PORT  MAC             DYNAMIC VLAN ATTRIBUTES
NUM                     CREATE PV  SV   I-SID  EV  VLAN NAME I-SID NAME  MVPN I-SID
1/14  00:00:00:00:00:01 pvlan  301 3001 1301   0   v301      isid301     100
Switch:>enable
Switch:1(config)#show eapol sessions neap verbose
                                    Non-Eap Oper Status Verbose
PORT  MAC              STATE        VLAN PRI Flex-UNI I-SID   NON-EAP VLAN:I-SID ACL  ACEs DYN    RADIUS DYNAMIC
NUM                                 ID       Enable   SOURCE   AUTH                        MHSA    SETTINGS
1/15 00:00:00:00:00:15 authenticated 1     0  false   n/a      radius                           IPSG, DHCPSNOOP, DAI, IGMPSNOOP
1/15 00:00:00:00:00:16 authenticated 1     0  false   n/a      radius                    BPDU, SLPPGUARD, WOL, AN-ADVERTISEMENTS:100F
Total Number of NEAP Sessions: 2
Switch:1>show eapol system
                                  Eapol System
                     eap : disabled
           Eapol Version : 3
         non-eap-pwd-fmt : mac-addr
     non-eap-pwd-fmt key : ******
 non-eap-pwd-fmt padding : disabled
 auto-isid-offset status : disabled
 auto-isid-offset value  : 1000
The following table defines parameters for the show eapol command.
                                 Variable  |
                                 Value  |
                                 auth-stats [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]  |
                                 Displays the authentication statistics interface. Note:
                            auth-stats [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] is useful only for EAP supplicants. The command output changes only when the EAP supplicant tries to access the network.  |
                                 port {interface [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] | {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}}  |
                                 Specifies the ports to display. If no port is entered, all ports are displayed.  |
                                 session-stats interface [gigabitEthernet {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]  |
                                 Displays the authentication session statistics interface.  |
                                 sessions {eap | neap} [vlan<1-4059>] [{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}] [verbose]  |
                                 Displays EAP and non-EAP authentication sessions on the port.  |
                                 summary port[{slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}]  |
                                 Displays EAP and NEAP clients.  |
                                 system  |
                                 Displays EAP settings.  |
