Use the following procedure to link the security association to an IPsec policy.
The IPsec security association and IPsec policy must exist.
You cannot delete or modify a security association if the security association links to a policy. To modify a parameter in the security association, or to delete the security association, you must first unlink the security association from the policy. You can only unlink a security association from a policy if the policy does not link to an interface. If a policy links to an interface, you must first unlink the policy from the interface, and then unlink the policy from the security association.
 - Select IPSec.
 - Select the Policy SA Link tab.
 - Select Insert.
 - In PolicyName, type the IPsec policy name.
 - In SAName, type the security association name.
 - Select Insert.
Policy SA Link Field Descriptions
Use the data in the following table to use the Policy SA Link tab.
 Name  |
 Description  |
 PolicyName  |
 Specifies the name of the IPsec policy.  |
 SAName  |
 Specifies the name of the security association.  |
