Configure a VNID
Use the following procedure to configure a VNID, which identifies one of the potential 16 million VXLAN segments that can coexist within the same administrative domain.
- Select VTEP.
- Select the Vnid tab.
- In the Identifier field, assign a unique value to this VNID.
- In the Isid field, specify the I-SID associated with this VNID.
- In the Action field, select one of the available actions: none or flush.
- Select Apply.
Vnid Field Descriptions
Use the data in the following table to use the Vnid tab.
Name |
Description |
Identifier |
Specifies a value that uniquely identifies the VNID of this VXLAN tunnel end point. |
Isid |
Specifies a value that uniquely identifies the I-SID associated with this VXLAN tunnel end point. Note:
A VNID must not have the same value as an I-SID. |
Action |
Choose one of the following actions to take with the MAC FDB:
OvsdbConfigured |
Specifies if the VNID is configured with OVSDB protocol support for VXLAN Gateway. |
