![Note](images/note.png)
If you enable the cfm spbm enable command, you cannot assign a MEP/MIP level to an individual SPBM B-VLAN or configure CFM MD maintenance levels individually.
Enables the global CFM MEP and MIPs for all SPBM B-VLANs.
Switch:1(config)# cfm spbm level 7 Switch:1(config)# cfm spbm mepid 12 Switch:1(config)# cfm spbm enable
The following table defines parameters for the simplified CFM commands.
Variable |
Value |
spbm level <0–7> |
Configures the maintenance level for every CFM SPBM MEP and MIP level on all SPBM B-VLANs. The default is 4. |
mepid <1–8191> |
Assigns a global MEP ID for all CFM SPBM MEPs. The default is 1. |
no cfm spbm enable |
Disables global configuration of CFM SPBM MEP and MIP levels on all SPBM B-VLANs. |
default cfm spbm level |
Returns maintenance level to default for all CFM SPBM MEP and MIP level on all SPBM B-VLANs. |
default cfm spbm mepid |
Returns MEP ID for all CFM SPBM MEPs to default. |
show cfm spbm |
Displays the global CFM MEP configuration for SPBM B-VLANs. |
