Perform the following procedure to display information about the installed power supplies.
Display power supply information:
Switch:1#show sys-info power Power Info : Power Type Input Serial Part Oper Max Fan Hardware Supply Voltage Num Num Status Power FlowType Revision --------------------------------------------------------------------------------------------------- PS#1 AC 110/220 1234A-12345 10951 UP 715 front-back 14 --------------------------------------------------------------------------------------------------- Power Voltage Voltage Current Current Power Power Supply in[V] out[V] in[A] out[A] in[W] out[W] --------------------------------------------------------------------------------------------------- PS#1 235.75 54.81 0.24 0.55 44.50 30.00
Switch:1>show sys power power-supply
Power Supply Information
PS#1 AC unknown -- -- DOWN 0 front-back --
PS#2 AC 110/220 2041U-30076 801092-00-01 UP 150 front-back 01
PS#1 -- -- -- -- -- --
PS#2 240.25 12.08 0.21 1.53 23.41 18.72
