Use this procedure to configure a management I-SID on a Fabric Attach (FA)-enabled port or MLT.
To configure an FA management I-SID for Auto-sense-enabled ports, see Configure a Management I-SID for Auto-sense Fabric Attach Proxy Switches.
Ensure that the port or MLT is enabled for FA.
This command applies to all traffic sent or received on a port or MLT, carrying the VLAN ID specified using the c-vid parameter. This parameter is optional.
Depending on whether the c-vid parameter is specified or not, the behavior is as follows:
If you specify the c-vid parameter, the FA Server transmits this VLAN ID as the management VLAN in the FA Element TLV. A client or proxy receiving this TLV uses this VLAN-ID for management traffic on the FA Server uplink.
If you do not specify the c-vid parameter, the FA Server transmits a management VLAN with a VLAN ID value of 4095 in the FA Element TLV. A client or proxy receiving this TLV uses untagged traffic for network management on the FA Server uplink.
An FA management I-SID can have a platform VLAN associated with it. For Layer 3 support on the management I-SID, you must create a platform VLAN by port and associate the platform VLAN with the management I-SID. The C-VID can be of the same value or of a different value than that of the platform VLAN.
If the management I-SID matches one of the FA Switched UNI (ELAN) I-SIDs (as displayed by the command show i-sid elan), then the platform VLAN is automatically associated with the FA-enabled interface (port or MLT).
Configure FA management on port 1/2:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#fa management i-sid 101 c-vid 101
Switch:1(config-if)#show i-sid 101
Isid Info
ISID ISID PORT MLT ORIGIN ISID
ID TYPE VLANID INTERFACES INTERFACES NAME
101 ELAN 3 - - CONFIG EXTRSERVER_101
The following example demonstrates the Origin as "auto-sense".
Switch:1(config-if)#show i-sid 500
Isid Info
101 ELAN - c300:1/45 - AUTO-SENSE ISID_500
Switch:1(config-if)#show interfaces gigabitEthernet i-sid
PORT Isid Info
ISID ISID ISID MAC
PORTNUM IFINDEX ID VLANID C-VID TYPE ORIGIN NAME BPDU SUNI
1/2 193 101 3 101 ELAN MANAGEMENT EXTRSERVER_101
1 out of 1 Total Num of i-sid endpoints displayed
Configure FA management on MLT 10.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface mlt 10 Switch:1(config-mlt)#fa management i-sid 101
Verify configuration of FA management on the MLT. Because the C-VID is not specified, the MLT displays as untagged.
Switch:1(config-mlt)#show i-sid 101
Isid Info
101 ELAN 3 - u:10 CONFIG EXTRSERVER_101
In the following example, for Layer 3 support, create a platform VLAN 3 and associate it with the management I-SID 101.
Switch:1(config-if)#vlan create 3 type port-mstprstp 0 Switch:1(config-if)#vlan i-sid 3 101
Switch:1(config)#show i-sid
Isid Info
15999999 ELAN 4048 - - C --- - --- - - Onboarding I-SID
16777001 ELAN N/A - - C --- - --- - - FAN-ISID
c: customer vid u: untagged-traffic
All 2 out of 2 Total Num of i-sids displayed
ORIGIN Legend:
C: manually configured; D: discovered by FA or EPT
M: FA management; E: discovered by EAP; A: auto-sense; R: multi-area redist
l: discover by local switch r: discover by remote VIST switch
Switch:1(config-if)#show vlan i-sid
Vlan I-SID
VLAN_ID I-SID I-SID NAME
1
2
3 101 EXTRSERVER_101
33
999
Because the management I-SID matches one of the FA Switched UNI (ELAN) I-SIDs, the platform VLAN is automatically associated with the FA-enabled port 1/2.
PORT Isid Info
ISID ISID ISID MAC
The following table defines parameters for the fa management command.
Variable |
Value |
i-sid<1-16777215> |
Specifies the management I-SID. |
<1-4094> |
Specifies the customer VLAN ID. Important:
If you do not specify a C-VID value, the port or MLT is untagged. |
